ESR Wheels
Here is my setup:
-Koni Yellows w/ Strano Springs (lower perch front, HH mod rear)
-18"x9.5" ESR SR04 Wheels, 5x120mm, +35mm offset
-245/40/18 Nitto NT555 Tires (small stretch, nothing extreme)
I had to run a 5/16" spacer to get these wheels to clear the front calipers, which I picked up from a parts store as a temporary solution. I will be installing extended ARP studs and custom hubcentric 7mm spacers as soon as they come in. This car isn't my daily driver, so I just used this setup to test fitment.
I bought the wheels through Unleashed Wheels, the guy I dealt with was very helpful and patient, and gave me a good packaged price, and warned me this design has trouble clearing calipers.
Let me know what you guys think:
According to my calculations, your front wheels will stick out of the fender about 8mm (~5/16"), your rear wheels will stick out of the fender about 21mm (~13/16"). The rears can be rolled and pulled to fit. The front are going to stick out a good bit, so you will either need an even more stretched tire than I used, or you will need to get creative with the fiberglass fenders.
Also, even with the lower offsets, you need to take a closer look as to where they make up that extra offset. If the lower offset is added in the barrel of the lip instead of the face, you will still need to run 7-8mm spacers to clear the brake calipers up front.
