gto spare
Old Sep 29, 2015 | 03:03 PM
kalildude's Avatar
Default gto spare
will a 195/55/17 tire fit a gto spare, if not what is the widest tire you can fit on it? 17x4 is the size of a gto spare.
Old Sep 29, 2015 | 11:55 PM
Bandit2000's Avatar
I don't have an answer for you, but I really hope you aren't looking to use those spares as drag rims.
Old Sep 30, 2015 | 11:29 AM
kalildude's Avatar
why not?
Old Sep 30, 2015 | 12:48 PM
k_garretson23's Avatar
its a very VERY common setup. I used them on my c5z. no issues.
they will fit but they will probably bulge. i forget the size i ran. they were m&h i think they were 26x4.5x17
Old Sep 30, 2015 | 02:55 PM
Bandit2000's Avatar
I know it's been done, me personally I wouldn't risk it. You can get a real drag wheel for not that much more then it would cost for a gto spare. Maybe it's because I'm a little older now but saving a few dollars isn't worth it to me anymore.
Old Oct 4, 2015 | 09:37 AM
gto spares are one of the lightest options for a 17" front runner. you cant get close to a gto front price for any 17" skinny. 15s maybe. a gto spare is probably stonger than most drag wheels anyway beingg that its made of steel.
Old Oct 5, 2015 | 12:48 PM
Rise of the Phoenix's Avatar
I don't see why you couldn't run that size of a tire on them.
Old Oct 12, 2015 | 03:31 PM
kalildude's Avatar
I got mine for 50 bucks each I got a hell of a deal. No skinnies are that cheap and I was just afraid that they the tire would be to wide for the rim for daily driving. I know it's not ideal but just a thought
Old Oct 15, 2015 | 10:39 PM
8UALIVE's Avatar
I had a set on my g8 I got for $50! Worked perfect as a drag setup.....people always said no way they would use them........I picked up .2 in the 1/8 with those! Never ran the 1/4 cause it's so far away....but a lot of guys run those wheels with the front runner tire on them....
Old Oct 16, 2015 | 04:20 AM
Tuskyz28's Avatar
What's the weight per wheel for a gto spare ?
Old Oct 16, 2015 | 10:06 PM
8UALIVE's Avatar
I don't remember exactly but they are light!! I wanna say around 20lbs....maybe 17....with a tire of course
Old Oct 19, 2015 | 04:18 PM
imma_stocker's Avatar
GTO spares with good tires are stronger than 15" prostar skinnies.
Factor in that fitting prostar or equivalent wheels require brake calipers be ground to fit in the wheel, require a spacer, AND most are lug centric. No way in hell the spares are more dangerous with equal tires on both rims. Put some 28" tall tires up front and all favor goes to the donuts.
That being said, the 17x4.5 racestars are my preference for brake clearance, NO SPACERS, hub centric, and they look cool lol
Old Apr 27, 2017 | 03:58 PM
54inches's Avatar
I have been researching this for awhile and the average saving vs. going Welds, etc is about $750. A good spacer and tires and with the influx of tuner sized tires, a 205 radial will fit, but is a tad wide.
A 195 is better, with I think a 185 is the best bet.......
