All NT05r users step in-considering the switch from Mickeys
Main question-are any of you having issues with the tire "feathering?". I am running 275/40/17 Mickey T Dr's and I am constantly having issues with the tire feathering up on the street. Doing a burnout cleans them up but only temporarilly. When they feather traction from a dig or roll is significantly reduced.
I know zbrown is having good luck with the N555's but beign a 6 speed and having a higher gear ratio, I need every ounce of traction I can muster! I would like to try the NT05r's but if they have the same issue as the mickeys I will have to rethink my strategy.
If you are unfamiliar with the issue- see below.
I never had an issue from my nto5r on my turbo Camaro nor my friend on his 10sec 5.0. I switched from an et street radial to the nt05r on my 17s but since they don't offer a 15 I had to go back to the et street radial when I went to a 275/60.. With my current zo6 it will be getting nto5r for sure.
This is for street and strip.
That being said I have not had the feathering issue when I ran the Nt05r nor do I have that issue with my Mt et streets
True story, I went from nt05r to Mt et streets and the traction comparison is not even close, tho the nt05r is a very nice all around radial, it really can't shake a stick at et streets as far as hooking.
I have about 3,500 on my current et's and they should last me all of next season which will put me at about 8,500 with plenty of track use. Keep in mind milage wise with my setup and at my power level I was able to turn the nt05r's over at will on the street but they are a harder compound.
With my et's they hook much better so I'm not leaving as much tire/rubber on the pavement and also depending on the surface, like a ruff textured road I will roll into it from a dig to prevent a absolute dead hook and boom goes the rear, if I break I want it to be at the track lol
With the nt05r's I was never worried about dead hooking on the street and knew they would give and break loose before my rear
Don't get me wrong I loved the nt05r, handled very well, able to hook and is a very good all around radial but traction wise and for the little you give up handling and milage wise the et street is where it's at imo
I got about 10,000 out of the nt05r with a lot of track use.
I can tell you its make a BIG difference! I don't mind burning out to clean off the tires, but my rear end is weak and cant take too much of that!
Do you feel the ET street hooked better than the Nitto?
Eh...I dont know about that. When I get the marbles on the tires, I seem to lose a lot of "stick". At the track I know the Mickeys will do better-but at what cost on the street?
