Some wheel and spacers questions
I just picked up a set of 4 corvette reps that are 18x10.5 with 56 offset. The car is off the ground and the wheels are making contact with the bump stops. I plan on running 295/35/18 for the rear and still trying to figure out what size to go for the front. I'll do some rolling if I need it rubs.
What i am confused about from searching the forum is spacers and longer studs vs wheel adapters. What is the safer route? I couldnt find a concrete answer. What size spacer/adapters should I get for the front and back? I know some people didn't need spacers but I'd like to use some to bring the wheels out a little. Car is set up to go around corners.
Thanks for any help in advance.
What I can tell you is that
1.) for a handling setup you want a square tire setup, so run the same sizes front and rear.
2.) with your car in the air you wheels might hit your bumpstops regardless of having a spacer especially if you have the stock PHB or a PHB setup at all vs an aftermarket watts link. This is common and what you do is jack the rear of the car up by the center of the axle so the wheels don't make contact. If you space the wheels too far out you might make tire contact with the outer fenders then on certain inclines or bumps.
You install longer studs to use their spacers...
spacers and arp studs is all you need
