Need help choosing tires!
Old Jun 15, 2017 | 02:46 AM
LS1TAUTO's Avatar
Default Need help choosing tires!
Need help choosing my tires my set up is torquer v2 241 heads 4K yank SS 373 rear ratio stock ws6 wheels wanting something chunky what size tire would be good for this setup anyone out there with similar setup chime in!
Old Jun 15, 2017 | 05:35 AM
stp001's Avatar
295mm 300 TW tops!!
Old Jun 15, 2017 | 01:59 PM
LS1TAUTO's Avatar
Originally Posted by stp001
295mm 300 TW tops!!
295 mm u mean width?
Old Jun 15, 2017 | 03:25 PM
stp001's Avatar
LS1auto, Oops, I didn't catch that you wanted the tires to fit stock rims. I'm sure 275 is about as wide as you will fit on 17x9 rims. I would recommend Falken Azenis RT615K. They are on sale at the largest online tire dealer right now for $123. It is a clearance sale, they wont last long!! They are being replaced by the "+" line. If you want a little more bite, get the RT615K+. They are a softer compound tire. These are not drag radials, these are grippy, good handling tires that do fair in the rain. About $200. With your mods and gears, traction could be an issue for harder compound tires.
Old Jun 15, 2017 | 03:29 PM
98CayenneT/A's Avatar
Hoosier DR2 or MT ET ss
