Wheel adapters
Old Sep 6, 2017 | 07:56 PM
1SCKLS1's Avatar
Default Wheel adapters
I have a 99 camaro ss with OEM 17x9 zr1 ss wheels looking to run 1 inch adapters don't know much about them I know have to run arp studs upfront to run them but my moser 9 rear has extended length studs how would the adapter fit would I have to cut the studs to clear the adapter ? Or do I just run a spacer in the rear ? And would this require rolling fenders ?And what is everyone running ? Any help I really appreciate it
Old Sep 7, 2017 | 12:18 AM
RedDeadG8's Avatar
www.motorsport-tech.com/
They make custom, and great quality adapters. you dont need to cut anything. adapters go over the lugs and have another set of lugs. make sure your wheels have some space for the lug nuts to fit into when the wheel mounts onto the adapter. dont use spacers. adapters are the best route.
Old Sep 7, 2017 | 03:00 AM
1SCKLS1's Avatar
Awesome man that is just what I was looking for usa made thanks quick question since my rear studs are extended I can go with there design 2 wheel spacer and then use design 3 for regular up front lugs?
Old Sep 8, 2017 | 06:49 PM
stp001's Avatar
If you have longer rear wheel studs, hubcentric spacers are the only way to fly.
On the front, spacers/adapters of a 1" dimension may require you to grind down the existing studs. As far as rolling fenders, check to see if you have an inch of space before buying spacers. Front or rear, don't get anything but hubcentric!
