4th gen 15" Weld RTS Wheels on 5th gen camaro?
So I have a set of 15x10" weld rts wheels off my 4th gen camaro I'm wanting to put on my 5th gen. Looks like the backspacing is the same for rts wheels made for the 5th gen and 4th gens and the offset is 51mm instead of 50mm which I doubt will be noticable.. My only worry is that the wheel studs on 5th gens are bigger then the 4th gens. Is there a way to swap to a smaller wheels stud?
Thanks for the info.. I wonder if the extra .65 is basically from the studs being 14mm instead of 12mm? I don't know what would be involved in putting a 12mm stud to replace the 14mm either though... Wonder who I could call to get some info on this?
