Wich drag tires
Old Jul 12, 2018 | 08:06 AM
one sweet ws6's Avatar
From what i can tell they do toon it for a spin the other day and got on it a few times never even churped them with 30psi if that was my nittos id b sideways.
Old Jul 12, 2018 | 10:10 AM
98_1LE's Avatar
Thank you.
Old Jul 15, 2018 | 08:42 PM
Dragula's Avatar
Cool!!! Give her hell!!! If she is hooking well you should be able to dump the clutch from 5000 to 6000 rpm. Let us know what your 60’ times are at the drag strip.
Old Jul 15, 2018 | 08:48 PM
Ok i will but im not dumping the clutch at no 5-6k
Old Jul 27, 2018 | 11:38 PM
Alittle update finally went to the track tonight. The tires were awsome i couldnt b happier i left at 4k on my last pass and they never broke loose. I ran 25psi all night didnt do a burn put drove around tbe water box. I ran a 60’ of 1.78 and 12.56 quarter @113 i was happy with that
Old Jul 28, 2018 | 07:44 AM
Dragula's Avatar
Great job! Nice 60’. Did you slip the clutch or dump it at 4000 rpm?
Old Jul 28, 2018 | 08:41 AM
Slipped it alittle but it still bogged down alittle not bad tho
Old Jul 29, 2018 | 06:07 AM
Dragula's Avatar
Good job! Great 60'!
Old Jul 29, 2018 | 05:35 PM
Thanks im still practicing ive only ever made about 15 passes in the car and up till now i never had good tires to hook up. I still think shes got slittle more in her. Next time i go im going with a set of skinnies ans less than 1/2 a tank of fuel
Old Jul 30, 2018 | 11:28 AM
Dragula's Avatar
Based on your mph you should be able to get a 12.1 or 12.2 with the right conditions. If you are slipping the clutch make sure you let the clutch cool down enough between runs.
