Eagle Alloy 077 center cap
Old Jul 30, 2018 | 06:46 AM
curacaoz28's Avatar
Default Eagle Alloy 077 center cap
Good morning. I have a set on Eagle Alloy 077 17x8. Looking for measurement or part number for the center cap. The middle hole measures 71mm outside and 66 inside
Old Jul 30, 2018 | 10:49 PM
OnA Fan's Avatar
I'm pretty sure mine are 9 or 9.5. Center caps should be the same on all 17s, no?
I'll get some measurements for you the next time I pull a wheel. I tried to pop a cap off but it won't budge. Don't want to snap the tabs.
Old Aug 1, 2018 | 08:20 AM
curacaoz28's Avatar
Okk okk thanx. Do uou maybe know if it are these wheel. We got centercap part number 3088-06 but they czmd ou small
Old Aug 2, 2018 | 07:22 PM
OnA Fan's Avatar
I just posted in your other thread. Yes, these are them.
Old Aug 13, 2018 | 07:32 PM
OnA Fan's Avatar
Took the measurements for you.
Outside Diameter is 75mm, The inside where the cap clips in is 60mm.
There is no part number stamped on the cap, just 139 in the center.
