Tire Balancing & shaving
Old Aug 24, 2018 | 03:51 PM
David_viny's Avatar
Question Tire Balancing & shaving
So I seem to be having a very hard time getting tires that don't vibrate. Last 2 sets of tires I had vibrated terrible. Stock size 275/50R17 on WS6 wheels. When I bought the second set and had basically the same vibration I tossed it up to something else causing vibration. New tires that are balanced AND road force tested (probably not correctly..) shouldn't vibrate right? Well I tried a separate set of tires/wheels and boom, no vibration at all (almost) so it is for sure a tire problem. And before anyone asks if wheels are bent, i checked them all with a dial indicator and were all within .005" TIR.
I believe the real cause is the tires are out of round. I drove the car around, jacked it up and checked the tires for out of roundness and they are between .030"-.060" out of round. This does make sense since most of them took a ton of weight to balance. At this point Ive given up on these tires/wheels and moving on to something else for now.
Now ive got new tires AGAIN on different wheels this time. Dinky 215/60R16 on steel wheels for my daily driver Camaro. I had winter tires on these wheels before and no vibration. These new tires measured approx .020"-.040" out of round brand new never driven on. Against my better judgement I drove on them anyway, figured the large sidewall will absorb most of it and it seems to be a trend for all tires to be out of round anyway... Still vibrations. Not that bad really, could almost accept it, 95% better then my first 2 sets of tires but still there.
So I guess long story short, does anyone know what is "acceptable" out of round numbers for tires? Does anyone shave tires to be truly round these days? Is it a common thing to do? I know no one in my area does it. Ive asked around and most have never even heard of it.
Old Aug 29, 2018 | 09:45 AM
biketopia's Avatar
What brand of tire are you using?
