Need help
Old Aug 26, 2018 | 04:45 PM
2000z28franz's Avatar
Default Need help
Wheel question??? I finally found some 17x11 zr1 rims with a 36mm off set. they should fit on the FRONT without a spacer.. but i like the look of the 17x11 deep dish with 50mm offset for the REAR.. my question is will the front stick out further.. im pretty sure the 36mm has deeper lug nut holes and the 50s have the bigger lip. Same size wheel
