What Wheels for 305/35r18 TranAm
What are some good chrome or polished wheel choices for 305/35r18 on a Trans Am without needing to roll fenders. Dont mind BFH on inside if needed. I have been looking at OE wheels Z06 staggered just not sure if the offset is right. I know very little about wheel sizing.
for starters, with a 305 you are most likely going to need to roll fenders as well as do a little BFH on the inner wheel well if you are lowered at all, probably get away with it if still stock ride height. you will be looking at an 18x10.5 wheel for that tire size if you didn't already figure that out. I'm running a 295/35 on an 18x10.5 rim at +50 offset front and rear and this is where it sits. i am lowered over 2 inches on coilovers so i had to roll my fenders and do a little clearancing on the inner fender well
sticky at the top of the wheel/tire section has the offset info you need for 18x10.5 on the rear
https://ls1tech.com/forums/wheels-ti...must-read.html
Sara (2001 Z28) is running 285x35ZR18 on 18x9.5 rims (46MM offset), she likes it a lot, she is stock height no wheel well modifications needed.
