ive made up my mind on a killer setup...input?
If you want 295/35/18's in the rear, you need a 18 x 10.5 wheel. The rear will sit approx. .4" higher because of the tire (compared to factory or a 275/35/18).
Any of them should bolt up just fine as long as they have the correct offset. Whoever you buy the wheels from can get you the correct offset for your combination.
