ive made up my mind on a killer setup...input?
17 / 8.5 in front with 265
18 / 9.5 in rear with 295_____or should i go with 18 /10.5 with a bigger tire?
will they just bolt on like my stock wheels and tires or will i have to get something else to make it all work?
thx for the input guys
oh yea i would love to lower my car but ive got SLP longtube headers im afraid i cant get lower unless I had some sort of air ride suspention that I could adjust inside the car...do you know anything about that???
Front - 17x9.5 with 275/40/17 or 18x9.5 with 275/35/18, +50mm to +53mm offset
Rear - 18x10.5 with 295/35/18 or 315/30/18 (check to make sure your tire manufacturer allows 315 on 10.5 wheel, e.g. Michelin Pilot Sport and PS2), +50mm to +53mm offset
Ideally you'd go less offset, but that's not an option with ZO6 wheels at this time.
ive got an important question: I cant afford to loose any more ground clearence but I also want to lower my car, now my TA came with stock 17" wheels and if i move to 18" all around wont that allow me to lower my car an inch with out looseing any ground clearance???
any feed back is really appreciated guys, if this sounds unclear let me know and ill try to make it sound more understanding
rear: 18" 9.5 wheel with 285 tire
with this added inch off the ground because of the wheels am I safe to lower my ride an inch and still have the same amount of ground clearence?
Oh yea will this setup look good and most importantly will this setup just bolt right on without any mods?
