28x10.5 ET Drag on Convo 15x8.5 wheel..will it fit...
28x10.5 ET Drag on Convo 15x8.5 wheel..will it fit on a lowered f-body? Car is lowered with the Eibach Pro kit <1.5" drop> or will i have to raise the back up to stock height?
I dont mind massaging the fenderwells, but will it clear the quarterpanel?
TIA
Brian
TIA
Brian
you need to raise the car...
wrong tire though for that rim...rim is way too small. Can you do it...well you can put a 315 on a 9.5 rim but not recommended so it's your call.
You need a 10 inch rim for that...I wouldnt even consider trying to stuff that tire on the rim. You need to go to a smaller tire like a 9 inch wide drag or a larger rim.
Steve
Steve
