Weld Draglite Fitment Help!!
Old Sep 24, 2004 | 05:38 PM
Black8Banger's Avatar
Default Weld Draglite Fitment Help!!
Ive got a 99 LS1 Camaro
I just got a pair of 15x3.5" Weld Draglites
In order to fit these on the car I know I need a 5/16" wheel spacer.
The local parts store is out of spacers right now so in order to double check the wheel fitment I put enough washers on the studs to equal a 5/16" spacer. After I did this I realized I needed longer wheel studs to even get the lugnut started!
Does anyone know what length wheel studs I need to be NHRA legal?
Old Sep 26, 2004 | 05:52 PM
anyone?
Old Sep 29, 2004 | 12:59 AM
01PewterWS6's Avatar
not sure, TTT for ya.
Old Sep 29, 2004 | 11:08 AM
Justin99TA's Avatar
Mine fit fine. What lug nuts are you using?
Old Sep 29, 2004 | 08:54 PM
Ive got stock lugnuts. My stock studs dont even come through the rim with the spacers on.
Old Sep 30, 2004 | 06:38 AM
BTL FED's Avatar
Thats the problem, when you use welds you have to use Shank Style lugs, they actually go into the rims, you cant use stock lugs with welds
Old Sep 30, 2004 | 02:50 PM
Ahhh, thanks for the info!
Is that safe to run? seems like its not enough strength?
Old Sep 30, 2004 | 05:19 PM
KMStevens's Avatar
I would NOT recommend using stock wheel studs with draglites, mine would only go in 1-2 turns, which is NOT safe at all!! I got a set of ARP 3" studs with the same thread pitch, now they have 10-15 turns into the stud, and I dont have to worry about the wheels falling off going down the road. BTW when you get wheel studs, find those spacers also, putting washers on just doesnt sound like the safest idea to me.
Old Oct 2, 2004 | 04:49 PM
Alright! Yea, the washers was just a test thing to make sure that was the right size spacer. I just put the washers on there and held the wheel up to the studs to see if the calipers hit the wheel.
Where did you get your ARP 3" studs? Ive seen the 2.5" studs at Thunder Racing but not 3".
Old Oct 2, 2004 | 05:52 PM
Fast SS on TNT's Avatar
Replied to your PM. There is no such animal as a 3 inch ARP stud in a 12mm X 1.5 knurl. I wish they would make some though!
Old Oct 4, 2004 | 01:17 AM
Matt D's Avatar
Retired Street Racer
i am actually looking to get the weld 15X3.5 and 15X10...what do i need as far as what size studs, spacers, lug nuts, etc...thanks in advance
Old Oct 5, 2004 | 10:04 AM
Casper9T9's Avatar
http://www.freewebs.com/casper9t9/dragwheelinfo.htm
Old Oct 6, 2004 | 02:16 AM
Matt D's Avatar
thanks casper9t9
