Need Drag rims but........
Originally Posted by Nine Ball
Yes, those Bogarts fit without grinding anything, and do not require any spacers. Your stock lug studs will work. The rear wheels are 9.5" wide, so they will work just fine for 10 or 10.5 wide rear tires. Many people run that combo.
Tony
Tony
just to clarify regarding fitment and what folks are using, a 10 inch wide rim is what is used...the welded setups i.e. D10's, DOS, welded RT ets end up 9.75 to be exact...the bolted P1's i.e. bolted D10's bolted RT's end up being a true 10 inch rim.
Regarding tire size, only choose the smaller 10 tire if your are using true DRAG tire NOT the ET STREETS or hoosier QTP...
...the SMALLEST ET STREET or hoosier QTP you would want to use with those rims are 11.5 wide.
hope this clarifies it for some.
Steve
Steve
