What size tires?
Old Nov 19, 2004 | 06:48 PM
dan102877's Avatar
Default What size tires?
I have 17x10 smoothies coming, and was wondering what size tires do you guys think would be the best (looking, and safest) to put on the front and the back? I also have an Eiback Prokit on there, so it is lowered a bit. And I don't want to have to do any hammering or anything like that. Thanks.
Old Nov 20, 2004 | 10:48 PM
5POINT7's Avatar
275/40's are fine for 10" wide wheels. I'm running them in the front on my car w/ 17x9.5" wheels and the tires are Kumho Ecsta Supra, which are great tires, btw.
For the best look in the back, though, I'd go with 315/35's (especially 315 Nitto DR's b/c they tend to run narrower than most other manufacturers). They'll fit good too and won't require major body modifications to fit. I've got the Eibach prokit on my car w/ 17x11's with 315's and cut and tucked the fenders and it looks completely stock from the outside. You can't even tell I've modified the body.
Old Nov 20, 2004 | 11:26 PM
2MuchRiceMakesMeSick's Avatar
Nitto is a good tire for your choice. Any decent tire for the front will do. A stiff sidewall is prefered
Old Nov 21, 2004 | 06:07 PM
dan102877's Avatar
I'm getting the Goodyear Eagle F1 GS-D3's all the way around. So you think 275/40's are good for the front, what about the back? I don't think a 315 is gonna fit in the back....especially since it is lowered! 285's? 295's? 305's?
Old Nov 22, 2004 | 12:39 AM
5POINT7's Avatar
275's will fit like a glove on the fronts. They'll do the same on the backs too. But IMO I'd go w/ 315's for the rears. They will fit on 10" wide rims. For point of reference, people have successfully run 315's on 9" wide rims without problems.
315's will give your car a mean look. Here are my 315's:
Old Nov 22, 2004 | 12:46 AM
dan102877's Avatar
But do you think 315's will also fit with the car lowered? what is the next size down? 305? Sorry...still trying to figure out the ***** tire fitment thing.
Old Nov 22, 2004 | 01:00 AM
5POINT7's Avatar
Yes they will fit, my car is lowered with your same lowering springs but with worn shocks so it's probably lower than yours. Next size down? I think 275. Search on tirerack.com or tires.com. I've never heard of anyone running 305 or 295 17" tires.
Old Dec 18, 2004 | 11:17 AM
04GTOman's Avatar
I thought you said it was lowered but you brought it back up top stock height? Make up your mind man.....and get rid of the Smoothies they just don't look right.
Old Dec 18, 2004 | 11:46 AM
5POINT7's Avatar
^^When did he say his car was stock height?
