Pics of C6 wheels!!!
5/16" spacer will help alot, 1/2 spacer should be just right. Just my .02 though. After that your Camaro will look badass!
Yeah I am pretty sure I used 5/16" spacers, not positive though. If the wheels were 18X9.5's instead of the 10.5's, a 1/2" spacer might be more appropriate.
Jammon, I had the local shop put my wheels on the car-the tires had to be mounted, etc etc. I think they had to do something to get the arp studs through one of the holes, but I can't remember exactly what the problem was. i think if you jack it up by the axle keeping the springs compressed, you'll be fine though.
Jack up car.
Remove wheels and tires.
Remove caliper assembly (two bolts).
Remove rotor retaining clips if your car still has them on there.
Remove abs/wheel speed sensor with one bolt. If you don't have it, which you should because yours is a y2k it's easy.
Pound out bolts through sensor hole.
Pull new ones through, you have just enough room to pull them past the ring gear.
Put washer over the new stud so you don't have to tighten as far and pull them through until snug with an old lugnut.
Very easy to do with access to air tools like I have. An air wrench makes quick work of pulling studs through.
With 1/2" spacers, I actually have more threads to work with than when I had stock wheels and no spacer. Plus the ARP's are chromoly, way way stronger than the stock ones.
Jack up car.
Remove rotor retaining clips if your car still has them on there then rotor.
Remove abs/wheel speed sensor with one bolt. If you don't have it, (which you should because yours is a y2k, it's easy) you have to drain gear oil and loosen the axles.
Put washers over the new stud so you don't have to tighten as far and pull them through until snug with an old lugnut.
http://www.thunderracing.com/catalog...vid=3&pcid=148
The pictures I posted above you can't tell that well ho far the come out to the fender. Here are some better pictures in terms of seeingthe offset from the rear.
http://www.cardomain.com/member_page...page_id=301043
(the 6th and seventh picture are real good shots for seeing the offset)
As far as the overall look, I am undecided. Contrary to what someone else said, I definitely think they look better on the actual C6. Overall, in terms of aftermarket wheels Id give the look a C+. If its lowered and you use some wheel spacers on the rear it would probably be upgraded to a B+
Just my measely 2 cents.
63-65mm?
Ahhhh, so that's why they looked so tucked in.
You gonna get some spacers and studs or what?
