Best tool to grind clipers to fit Weld Prostars?
Derek
I won't be buying the tires till Feb. so I can grind the calipers with just the wheel as my stencil? I don't think I will go with the skinnies just yet. Gonna run DRs on these.
Would a 6.5" backspace make it look better? or should I get a spacer too(5/16th, I assume)
I noticed you run a 275. Can I run a 295 or a 315 DR on these? I know MT make em but for fitment. Banging in the wheel well is OK.
Retired Street Racer
yeah, they would stick out too far. for a 15x10 go with 7.5in BS, and 15x8 go with 5.5in BS. with the 8in rim, you don't have to grind as much and still run a 10.5 in tire. i have 27x10.5x15 et streets on mine. here is a link that should give you an idea on how much to grind:click here!!!
Originally Posted by black02-z28
I am running 15X10 prostars with 7.5" backspacing. If you drag race most places will not let you pst tech with a spacer on the drive wheels. The above link is a great idea of where to grind. I used a 4" grinder, $38 at sears. It has done 3 cars. Here are mine:\
Ed
![](http://www.streetsleepers.com/caliper2.jpg)
![](http://www.streetsleepers.com/caliper.jpg)
Ed
What tires you running with those? Are those powdercoated or spray painted? Mine will be Rustoleum-ed. LOL Thinking this will be added to the project list over the holiday
#33
I am running MT drag radials on the prostars and have ET streets on draglites too. That is brake caliper paint from Advance. It was like $15 and has lasted over a year and still looks nice. I think they get too hot for rustoleum
Ed
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Ed
#34
Ed
Ed
I meant what size? Just trying to see how big I can go. Thanks.
#35
The ET streets are 26X11.50, I forget the exact #'s on the drag radials, they translate to 26X10.50. Neither have any problems. I have lowered the nose with QA1 shocks and lowered the rear by taking the spring pads out. I don't have any good closeups of the Prostars (I forgot to take any!) I have found that the draglites need more gringinding than prostars. I originally gound mine to clear the draglites and then my buddy used my prostars to grind his. The prostars ran fine. When he borrowed my draglites they rubbed.
Ed
![](http://www.streetsleepers.com/DSC04044.jpg)
Ed
