Feel like a moron on this one
-JOSH
315 is the width of the tire in milimeters, 35 is the sidewall height as a percentage of the width. So in this case the sidewall is 35% of 315. The R17 means it is on a 17" diameter rim. I don't exactly know what the R means, but if it is a Y or Z rated tire the company can put ZR17 instead of just R17.
the "R" stands for Radial
TireRack.com has good prices on tires. They had the best deal on the Eagle F1's that I just received today.
You can convert between inches and mm by multiplying/dividing by 25.4. You want a little bit of hangover on the sides to help protect the rim. Generally speaking, if you have an 9.5" rim, add an inch for the lips of the rim, so 10.5". That equates to roughly 266.7mm. So, minimum, I would probably go with a 275mm section width. You can use the above calculator to make certain you get the series number correct
(keeping the OD roughly the same size as stock so the speedometer will remain accurate).
ie, 285/40R17 for the front + 285/35R18 for the rear --- whatever you decide to do -(this specific selection would keep the speedometer within .5% accuracy, with both tires being roughly 26" tall and 11.2" wide). You could decrease the front tire's width to 275, or increase the rear wheel width to 295 or 305 perhaps, but the wider you go, the more the sidewalls will have to pull in to fit the rim, and the more you'll have to adjust the series number (sidewall height) to maintain overall tire diameter...
Make sense?
but do you need to know what kind/sizes to put on your new rims?
