Drag rims fitting?
Old May 8, 2005 | 01:53 AM
Silver 00 SS's Avatar
Default Drag rims fitting?
What rims fit perfect for a 00 SS, i dont want to grind or use spacers what rims should i get. Welds, drag lites....??? im thinking a tire size of 275x60x15
thanks for help!
Scott
Old May 8, 2005 | 04:08 AM
a98ws6's Avatar
Bogarts or some centerline's
Old May 8, 2005 | 08:24 AM
GM Muscle's Avatar
Yep, the only wheel that is a direct fit is Bogarts, Centerline does have one that fits but they don't look good and stick out from what I've seen. The tire you listed above is a 28'' tire. Expect to do some pounding in the wheel well and possibly a touch of trimming to make them fit.
Old May 8, 2005 | 03:08 PM
So, should i just stick to 275 50 15's?
Scott
Old May 8, 2005 | 05:16 PM
GM Muscle's Avatar
Unless your running some crazy amount of gear with the nitrous, I think that the 26" ones will work.
Old May 8, 2005 | 05:48 PM
just 3.73 with a 150 shot
Scott
Old May 8, 2005 | 05:52 PM
Where do you get Bogarts from??
Scott
Old May 8, 2005 | 05:55 PM
GM Muscle's Avatar
SJM Manufacturing sells them. Their banner is over there >>>>>>>
They are not cheap but they are nice.
Old May 8, 2005 | 09:03 PM
WhiteSSP's Avatar
From what I've seen, the centerline Telstars fit without grinding. At least on LT1 cars. Even the rears were fine, and IIRC both cars have the same rear brakes. And they now make them in the correct backspacing (15x8 5.5" backspacing).
Old May 8, 2005 | 09:10 PM
Tally TransAm's Avatar
i dont think they fit ls1 brakes without grinding
Old May 8, 2005 | 09:17 PM
TRYTHSS's Avatar
i know for a fact that my weld prostars didnt fit, i had to do alot of grinding.
Old May 8, 2005 | 09:56 PM
you should see the holeshots
