Check this out! Black ZR1's with 335s!
Originally Posted by LS1POWER98
![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
![Wave Finger](https://ls1tech.com/forums/images/smilies2/wave-finger.gif)
Originally Posted by LS69TA
Those look good. Now all you need to do is black out the windows.
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
Sorry, but I had too. The shot from the side looks so famliar. ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Looking good.
![](http://s05.imagehost.org/1078/black6.jpg)
You put 20's on a TA with 235's therefore your comments on anyone's set-up are null and void.
Looking good.
![Headbang](https://ls1tech.com/forums/images/smilies2/headbang.gif)
![Rotflmao](https://ls1tech.com/forums/images/smilies2/rotflmao.gif)
Best response to own someone I've read in weeks.
Hahahaha, way to be.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
![Owned](https://ls1tech.com/forums/images/smilies2/owned.gif)
Ritz what tint percentage is that? Tint is just around the corner for me.
20% all around. IMO any darker poses a problem at night on dark roads because if you have darker than 20 and someone doesn't have their lights on or there's a bike/pedestrian you most likely won't see them if your windows are up.
It looks even darker now because I have T-top shades on, so there's no light coming in from the top. In the middle of the day I couldn't even see my fiance sitting inside my car. I love it.
No problem. Now you have me thinking about 335's. ![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
How much did those tires run you and did you run into any issues installing them? I don't have any rubbing with my 315's and that's including with hard turns.
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
Only issues are a bit of rubbing, but I have yet to go back for round two with the BFH. As of right now it will only rub going into a driveway or on very hard cornering. Im sure round two will be able to iron these problems out. Also, it will rub from time to time on the LCA ever-so-slightly, so im looking to grind down the lip on the factory cast piece. And lastly, I'm still running the stock panhard rod so Im sure and adjustable would help quite a bit as well.
I wouldn't think 335s would cost a whole lot more than 315s, give it a shot when its replacement time...or just MAKE it replacement time.
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
#33
#37
Originally Posted by BawlsZ28
Don't let the slammers get you!! It looks brilliant and you can do more with racing in mind w/o lowering!
Thanks again J and ill keep you posted.
