10.5 x 18 c5 rims
Old May 26, 2005 | 08:41 PM
heymoej's Avatar
Default 10.5 x 18 c5 rims
hey, i just recieved my 10.5 x 18 c5 rims for the rear of my 2000 ss & i have a pair of 305-35-18 nitto 555r on there way here to go on them.i have the sportline lowering springs on my car now,do you think i will have a problem with the 305s out back??????thanx john
Old May 31, 2005 | 09:05 AM
Xsta Z 28's Avatar
You will more than likely have rubbing issues, but without knowing the offset (I assume 58) you will rub the inner wheel well. I rubbed with 295's. Time for the BFH mod . .
Old May 31, 2005 | 09:24 AM
777's Avatar
777
you will need some sort of adapter with those wheels if they are the typical offset of the 10.5 y2k replica wheel (don't remember off-hand what it is)
Old May 31, 2005 | 09:48 AM
dug's Avatar
dug
How well do the nitto's hook?
Old May 31, 2005 | 12:03 PM
heymoej's Avatar
my 17 inch nitto 555r hook real good when warmed,thats why i am getting them for my 18 inch rims.i will let you know how the 18s work out for me!!!!!!
Old May 31, 2005 | 01:03 PM
dug's Avatar
dug
cool
Old May 31, 2005 | 01:43 PM
blaSSt's Avatar
I'm running 18x10.5 Z06 (+58MM offset) wheels with the 305/35/18 Nitto DR's. I needed the BFH mod with 3 MM spacers and ARP studs (for safety). The car is lowered 1.5" on QA1 shocks and goldline springs. It also has BMR control arms and adjustable panhard bar.
Lowered, you MUST have an adjustable panhard bar to make sure the rear is centered.
With a lot of BFH and the spacers, my tires clear well inside and just miss the inner fender lip without rolling.
Old May 31, 2005 | 02:50 PM
dug's Avatar
dug
blaSSt
How much traction do the 18" nitto's give you?
Old May 31, 2005 | 08:42 PM
blaSSt's Avatar
I've pulled 1.69x 60' times at the track when it was prepped well and I did a good burn out. Cruzin around town the still break loose pretty easily.
