zr1's and prokit?
Old May 31, 2005 | 10:17 PM
Strokinit383's Avatar
Default zr1's and prokit?
Will the zr1 17x11's with 315 tires fit with the prokit rear springs?
Old May 31, 2005 | 10:41 PM
MissBehave's Avatar
Yes, they will fit
Old Jun 1, 2005 | 12:46 AM
hpjunky98's Avatar
ya with some modification
Old Jun 1, 2005 | 01:27 PM
Xsta Z 28's Avatar
They fit, with doing the BFH mod and rolling quarter lip,
and you will hate the springs in 1 year and want different ones . . .
Old Jun 1, 2005 | 01:33 PM
777's Avatar
777
I disagree...I have them, no inner wheel modification. Just rolled the fender lip, because they sit right on flush with the fenders. I'm using worn stock shocks, and have had these springs on for quite awhile I'm sure it's been more than a year.
Old Jun 1, 2005 | 01:34 PM
777's Avatar
777
I know they are notorious for sagging in the rear, however, my car actually sits a little lower in the front. (1/4" maybe) BTW what shocks do you recomend as I'll need some later on. I'd like it run nice at the strip and around on the street. However I don't want to be broke.
Old Jun 1, 2005 | 02:28 PM
Xsta Z 28's Avatar
You have the 36 / 38 mm offset wheels, on a Firebird, so that is why no inner wheel well mods.
Old Jun 1, 2005 | 02:42 PM
Yeah i figured i would have to roll the lip and use the BFH. Thanks for the quick replies.
Old Jun 1, 2005 | 05:20 PM
Derek98z's Avatar
I did it with the 50/56 whatever offset on my Camaro. Still no inner fender BFH needed. Just rolled the lip and got an adjust. panhard bar. This pic is with prokit
Old Jun 1, 2005 | 05:38 PM
C.J.'s Avatar
how hard is it to roll the inner fender lip?
Old Jun 1, 2005 | 06:02 PM
Some people use a baseball bat to do it. But eastwood sells a lip roller that bolts to your hub and you just crank it and it will roll it.
Old Jun 3, 2005 | 08:45 AM
skimms98's Avatar
50mm 17x11 rear and 315's here with Prokit....I had to BFH and adj. Panhard AND roll my outer lips.....ALOT. But it's not hard if you're careful...
Old Jun 3, 2005 | 09:36 AM
777's Avatar
777
yup
