GSD3s or Nitto DRs?
Have you thought about just buying another set of wheels for the track ? I picked up an extra set of used wheels for the rear and threw the Nitto's on those.
Yes they rubbed, when I bought the car it eagle f1's on it and they didn't then I bought these and they did, big times, inside and outside, these things are huge 315's. I grinded and smoothed the lip down with my drimel(still needs a little more) and beat the inside with a hammer and re-coated it.
But they do Cost$$$$ $220/tire
"Yeah I ran a 11.595" "Cool, I ran a 11.624, meet me behind the abandoned warehouse." Then you get owned because you're still running you're stockers in the back when your not at the strip. Just get the best traction, wet traction and highest tire ware tire you can, and use that. I personally like the GSD3s.
On one hand, one set of GSD3 run $1000 and should last 2 years.
On the other hand, one set of Nitto R's run $800, but only last 6 months. so figure 4 sets over a 2 year period and you are looking a $3200.
$3200 - $1000 = $2200 saved over a 2 year period.
I'm going to miss the Nittos, but I can't afford to run them in the long run. I'm a poor boy.
for the little bit of extra traction, its not worth it, idk what ur running, but itll still beat the pants off any mustang, and thats all that matters, right
I don't know, these GSD3 feel real sloppy. I may have to sell them and get some different ones.
I used to run the 555RII's at 32-34psi cold, but for some reason they started to feel soft in my opinion. The higher pressure losses grip just a little, not much, but they respond much quicker to steering input.
