NEED PICS! Difference between 36 and 50mm offset for 17x11....I've already searched!
I am going to buy some wheels for my Formula, and would love to see the differences between the 36mm and 50mm offset for 17x11 wheels. I don't want the wheel to go past the fender....i think that would look wierd. I also have the pro-kit on the car.
Thanks in advance!
Thanks in advance!
This guy has the 36mm offset Zr1's on his formula.
http://www.johnbrown.net/
I'm sure you can fine a pic of a 50mm offset Zr1 in this thread:
https://ls1tech.com/forums/showthrea...2&page=1&pp=20
I think you will be happy with the 50mm offset since the 36 may require you to roll your outer fender lip.
i have a TA and a Z28, i had 36 mm offset zr1s on the z and they stuck way to far out. Then i put them on the TA, PERFECT. The actual fender to fender width on a TA is about 1.5-2 inches wider. Which makes the 36's percect. Then i bought 50's for the Z, perfect!
