c6 wheels
Old Oct 3, 2005 | 08:56 AM
cls1go's Avatar
Default c6 wheels
well c6 wheels 18''x8.5 and 19''x10 fit a 98 camaro if so can i some pics
Old Oct 3, 2005 | 12:14 PM
spy2520's Avatar
i think you gotta do some funky stuff to get the back to fit.
Old Oct 3, 2005 | 12:37 PM
Deep Blue's Avatar
Post
18X9.5 fronts are not the stock GM wheels. OEM fronts are only 18X8.5 and go directly on; I just installed some this weekend. The OEM rears will go on with a 1.25 inch thick bolt-on wheel adapter or a custom machined spacer. I'm at stock ride height, so I can't say what may be required on the rear if you lower significantly and the suspension geometry changes, but from what I could see, 3/4 to an inch lower shouldn't change things too much. I will post pics when I can get them developed.
However there are reproductions out there that would allow you to bolt right up and even go wider in the front. Check with one of our sponsors. I went with OEM because I wanted the Competition Grey color.
1998 TA Navy Blue Metallic M6
Old Oct 3, 2005 | 09:22 PM
785T/A's Avatar
You are right the fronts fit fine but the rear is a little tough. first i tried a 1.25 inch adapter but it was too much for my car since it is lowered 2 inches. i tried alot of things and i came up with 3/8 inch spacer with longer studs. this works fine but i really wasnt happy so i called the company in georgia (bones enterprises) and they sent me a new set of rears with the correct offset for f bodies. I just have to get them mounted and send the old ones back.and they paid for all shipping and mounting.
Old Oct 3, 2005 | 09:41 PM
Deep Blue's Avatar
Thumbs up
Looking good! They may have started on a chevy but the C6 makes a nice Trans Am Wheel IMO. The other advantage to reproductions is you can get them without the Corvette logo.
Old Oct 3, 2005 | 10:07 PM
spy2520's Avatar
hey those are the wheels i'm getting, i see they are getting more popular like i hoped they wouldnt. I'm sure you were hoping the same thing, hehe.
Old Oct 18, 2005 | 07:28 PM
cls1go's Avatar
i can get adapters 1.25 with studs $200.00 call davinci motorworks ask for don 618 222-1201 in stock easy fix
Old Oct 18, 2005 | 10:59 PM
slayer6x6's Avatar
Im actually selling a set if you didnt already buy them.
