If you have CCWs SP50xx or 19+s please read
I am going to get the CCW SP505a. CCW suggests 19x10 for the front and 19x11 for the rear. I am wondering why not 19x9.5 for the front. That would be some weight savings. Not sure what you get with the 10 up front. Tire width choice should be the same for either wheel.
What are you running for tires in the rear if you have 19x11? I am wanting at least a 315 but it looks like my options are closer to 305 or 325. I am guessing 325 could be iffy on the fit.
If you went with 20x11 on the rear - why? Going for staggerred look?
I have read just about all there is in this section on CCW. If I missed a relevant post please point me to it.
Kleeborp the Moderator™
19x10 compared to 19x9.5 in terms of the weight difference would be negligible. I'd do the 10 up front, only because my 18x10s fit very well.
Up front I use a 275/35 tire, and in the rear I use a 295/35. The rears rub a little bit, so you'll have to do some light massaging.
i would go 19x10 up front and 19x10 or 19x11 out back, but i would suggest going with a 285/30ZR19 instead of a 275/30ZR19 on the front....why?....because a 275 on a 10 inch wide wheel looks stretched in my opinion.
this is how i'd do it.
1. 19x10 all around, 285/30ZR19 front and 295/30ZR19 rear
or
2. 19x10 with 285/30ZR19 up front and 19x11 with 305/30ZR19 out back
i hope this helps ya.
or
