98 corvette wheels on f body
Yes they will fit. The fit will be tucked into the fender though. Optimal offset for a f-body on vette replica's are 56mm or 53mm. The OEM's have a greater offset causing the wheels to set in the fender more. If it were me I would pass on them. Just because of the offset
Check this Sticky out. It show the proper offset's and fitments. I don't know the exact offset of the OEM vette wheels but I know it is greater thatn 56mm's
https://ls1tech.com/forums/wheels-tires/120716-wheels-tires-everything-you-should-need-know-here-must-read.html
