z06 rim pics please!!
Post em please, thanks..
Front 18/9.5 56mm offset 275/35 Kumho's at the time of the pic running 275 GS D3's now lowered on Eibach Prokit
Rear 18/9.5 56mm offset 275/35 Kumho's running 25/35 GS D3's now lowered on Eibach Prokit
If you run ZO6's get 10.5's in the rear with a 53mm offset if you can find them and that will put them flush with the fender.
I want new rims anyway, so hopefully I wont be looking @ that problem for much longer
Mine poke out pretty good even with a 265/35. I'm using a 1/2 inch spacer though. If you have a Camaro, your fenders aren't quite as wide as mine so you won't need as much. These are 56mm I believe.
