Diameter difference between 315 and 275 Nitto
Old Oct 11, 2005 | 11:26 AM
The Dragon's Avatar
Question Diameter difference between 315 and 275 Nitto
I was told that a 315/35/17 is 25.68" and the 275/40/17 is 25.55"; is this correct?
Wanted to verify before I make the adjustment in the program.
Thanks!
Christopher
Old Oct 11, 2005 | 11:38 AM
Xsta Z 28's Avatar
http://www.discounttiredirect.com/di...foTireMath.jsp
Per the calc they are only .02" different . .
Old Oct 11, 2005 | 11:44 AM
The Dragon's Avatar
Wow! The ride height felt a LOT more than .02" . . . I'll keep it the same in the tune and have a Sherrif buddy Radar gun me to see if the speedo is the same
Thanks again!
Old Oct 11, 2005 | 11:49 AM
The Dragon's Avatar
The local race-shop where I had the tires installed lists the measurements as the one's in my original post
Old Oct 11, 2005 | 11:56 AM
Xsta Z 28's Avatar
Tire diameter = ((tire width in inches x aspect ratio) x 2) + wheel diameter
1" = 25.4mm
275mm = 10.82677"
((10.82677" x .40) x 2) + 17" = 25.66142"
315mm = 12.40155"
((12.40115" x .35) x 2) +17 = 25.68109"
Thats the calculation . . . .
Old Oct 11, 2005 | 12:02 PM
The Dragon's Avatar
Question
1" = 25.4mm
275mm = 10.82677"
315mm = 12.40155"
Please forgive my ignorance but does the 2nd number in the tire size matter? 35, 40?
Why does it "look" like it fills out the wheel well more? Is that just an optical illusion because of the 11" width of my rim?
Old Oct 11, 2005 | 12:04 PM
Xsta Z 28's Avatar
The second number is the "aspect ratio" or the percentage of the tread that equals sidewall hieght.
The wheel well looks "fuller" since you have a wider tire, and it sticks out further than the OEM wheel.
Old Oct 11, 2005 | 12:07 PM
Xsta Z 28's Avatar
Sidewall hieght = (tire width in inches x aspect ratio)
275mm = 10.82677"
(10.82677" x .40) = 4.330708" tall sidewall
315mm = 12.40155"
(12.40115" x .35) = 4.340403" tall sidewall
Old Oct 11, 2005 | 12:38 PM
The Dragon's Avatar
Cool.
Thank you!
Old Oct 11, 2005 | 01:14 PM
Xsta Z 28's Avatar
Yup, glad to help, tire sizes can get confusing.
