what yall think about these wheels???
http://cgi.ebay.com/ebaymotors/18-WH...ayphotohosting
i like the deep dish look...would these fit a 99 stock trans am???
Originally Posted by lt1fbody355
I run the adr sterling with 5x120mm bolt pattern no problems. Its better to run them with hubcentric rings but I didn't for over a year.
Originally Posted by Xsta Z 28
Bad advertising by that E-Bayer . . . incorrect bolt pattern . . . Yes you can make them fit, but the lug studs will have some abnormal stresses on them.
Originally Posted by toofless916
"abnormal stresses" would you advise against this. that doesnt sound too good "abnormal stresses"...if the bolt pattern is off then i probably will not pick these up...besides there are specials running from tomzwheels that i cannot pass up...haha
I'd never run incorrect bolt pattern wheels on my car. Nor would I ever run a wheel w/o the correct hub ring.
Originally Posted by WhiteSSP
I would imagine that that .75 or whatever mm would be easily fixable by a dremel, am I correct?
TomZWheels is running a special on Chrome Z06 wheels for forum members. They are $599 a set plus shipping. The sizes available are 17x8.5 17x9.5 18x9.5 and 18x10.5. Choose any size combo for the same price. The truck is on its way and we’ll begin shipping next week. Give us a call at 1-866-939-1030. Our e-mail address is tomzwheels@aol.com. Any questions let us know.
Thanks
Thanks
You are only talking about roughly a .5 mm over a distance of 4.75". If you take into consideration that the center of each lug stud will only be about .25mm off center not to mention using acorn style (tappered) lug nuts, I see no problem with it. You won't be breaking any studs. Your rear end will go way before your studs will. I personally have these wheels and they fit like a glove. Slide right on like they were made for the car. If you didn't know that they had a different lug pattern and put one on you wouldn't be able to tell the difference. Just to clarify my level of expertise in this area I have been an auto technician for 20 years. I used to work with Dennis Lugo of Lugo Performance in Central Florida. I also used to set up the suspension,align and true tires for several guys who ran SCCA autocross out at Matrin Marieta in Orlando and have dealt with my share of wheels, lug studs, axles you name it.
