295 tires on a 9.5" wide rim?
Old 10-19-2005, 02:23 PM
Brian2006's Avatar
Default 295 tires on a 9.5" wide rim?
How do they fit? Will they fit? Any buldges? Anyone have this setup? Any pics?
Old 10-19-2005, 03:25 PM
lt1fbody355's Avatar
295's on an 8.5 rim. Here we go
Old 10-19-2005, 05:05 PM
Xsta Z 28's Avatar
Per manufacturer's recommendations 295's require a 10" wheel. . . .
I cannot believe that a shop mounted 295's on 8.5" wide wheel for you - pathetic.
Old 10-19-2005, 05:15 PM
Deep Blue's Avatar
Old 10-19-2005, 05:33 PM
Brian2006's Avatar
So do yall not suggest it? Or will I be fine?
Old 10-19-2005, 05:35 PM
GFORCE1320's Avatar
If they are allready mounted then I wouldn't worry about it but if I had to do it all over again, I would get a bigger rim or smaller tires. I'm sure they will be fine.
Old 10-19-2005, 10:05 PM
Xsta Z 28's Avatar
I do not suggest a 295 be mounted on a 9.5" wheel. EVER.
Old 10-19-2005, 11:06 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
I would do a 285mm. That should be perfect. Or even a 275mm.
Old 10-20-2005, 03:14 PM
Brian2006's Avatar
Well I have 275 kuhmo street tires but wanna go with a wider drag radial on the same rim. I've just heard 295s will do.
Old 10-21-2005, 04:26 AM
TOO Z MAXX's Avatar
Yes a 295 will fit on a 9.5 inch wheel. 10 would be better. I have them mounted on a 9 inch wheel and have autox the hell out of them and had no problems at all.
Quick Reply: 295 tires on a 9.5" wide rim?
