will 335/30/18 go on a 11"
pics, if available. im about to get my wheels widened to fit the 335 and want to know if 11" is enough, or should i go wider??? tires are pilot sports
I'd say wider. At least 11.5 maybe more. 11's are for 315's and you have 2 more centimeters width.
I'd wait for some expert advice, but I'm thinking you are going to have to go 11.5 or a little more.
LS1Tech Sponsor
Id like to know also. Im getting mine widened to 11 in the rear and want to know the widest tire i can go with. Thanks
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
I have the 11" rims on my 2000 WS6 and they are certainly nice but my tires are 315/35/17ZR. The tires fit no problem on the wheel, the only problem is fitting the wheel on the car itself. I opted for spacers to make sharp turns easier but I have friends who don't use them and they have problems with the tires scuffing the inner wheel-well on the slightest turn. Id say you could probably fit the tires on the wheel but you will definately have a hard time fitting the wheel on the car. So I say try it but use spacers and longer hub studs.
