Help on picking a tire
Is .56 a good offset?? Whats the good and bad of a .56??
I'm thinkin 265/35 on the front and 285/?? on the back....I want the sidewalls to be the same on the 285 as the 265....so what would that be?? 285/40??=same sidewall hieght as a 265/35??
There is absolutely no point in running different width tires on same width wheels, you will regret it.
As for a 265 and 285 combo of the same height, there isn't one.
A 265/35ZR18 is too short and a 265/40ZR18 is too tall, compared to a 285/35ZR18
If you insist on a a narrower tire for the front run a 8" wide wheel witha 245/40ZR18 and a 9" wide wheel in back with a 275/35ZR18. Then you ahve two tires of the same OD.
I'm thinkin I'll go 275/35 all the way around then....my Toyo's are gettin' beat!!
Won't hold pressure,they're worn down,and the the sidewalls on 2 are chewed up due to numerous flats!!
abadss...how much did you end up paying for rubber?? tirerack??
