TT2's and Corvette brakes clearance??
they should fit.i have the baer gtp kit on with my tt2's and they are 13.25" rotors.the calipers just barely fit though.i couldn't run weights on the rims because the caliper will knock them off.the caliper in the baer kit is the same as the c4 vettes.maybe you can find someone that lives by you that has tt2 and try one on.or a stock 17" rim should work also to check the fit.
Originally Posted by Xsta Z 28
No it doesn't. The spoke of the TT-2 curves in too fast and WILL hit the caliper. Options are a small spacer, or research going 18". I know Tom Henry put 18" x 8"s up front and 18" x 10"s out back on his THSS
Do you have any pics? there was another memeber that couldn't get that combo to fit without grinding
