CenterLine ConvoPro's *HELP!!!*
Old Nov 25, 2005 | 07:47 PM
MY LS WON's Avatar
Default CenterLine ConvoPro's *HELP!!!*
Anyone have pics of these on a 98+ TA? I want these really bad, 15x4 (front), 15x10 (rear)... am I going to have a hard time getting these to fit over the front/rear brakes? What backspacing should I get? Lemme know, thanx!!!
Old Nov 27, 2005 | 05:47 PM
MY LS WON's Avatar
Would a 5" backspace look stupid on a 15x10? I dunno
Old Nov 27, 2005 | 06:25 PM
SgtB's Avatar
7in on a 15x10
i asked a couple of weeks ago
5-5.5 on a 15X8
Old Nov 27, 2005 | 07:52 PM
gollum's Avatar
The Convo 10's will extend too far out from wheel well so you may want the narrower 8.5" version with 5" backspacing.
Bogarts 10" are the best fitting with the most offset that does not require grinding.
Old Nov 27, 2005 | 08:22 PM
vmax1500's Avatar
This is my Bird with 7.5" Convo's out back... unless you are making pretty big power you don't really need a wider rim...
Old Nov 28, 2005 | 04:30 PM
DanZ28's Avatar
Fronts require no grinding at all as thats what I run. I to want to pick up some rear convo pro's but i believe they require caliper grinding right?
Old Nov 28, 2005 | 04:35 PM
vmax1500's Avatar
I have 7.5" wide rear Convo's and they bolt on with no grinding... if you want a 10" wide rim this is not the best choice as the off set is not ideal... this is the least expensive way to get into a set of simple bolt on drag rims with an LS1 F-Body...
Old Dec 1, 2005 | 11:45 AM
MY LS WON's Avatar
Thanks for the help guys, I'm getting my rear end narrowed 3 1/2" and going to run the 15x10 convo pro's with 5" backspace,
Old Dec 1, 2005 | 01:09 PM
slvrhwk's Avatar
Post pics when you get it done
I've had the 8.5 rears one two different cars with no grinding.
Old Dec 1, 2005 | 04:46 PM
mrr23's Avatar
which backspacing are you guys running for the fronts? 1 3/4" or 2 5/16"?
Old Dec 1, 2005 | 04:52 PM
mrr23's Avatar
pwtrws6 - what tire you running? i'm debating on 26x11.50-16 or 26x10.50-16
Old Dec 2, 2005 | 06:36 AM
slvrhwk's Avatar
The fronts are 1 3/4 bs and the rear tires are 26x10.50x15.
Hope this helps
Old Dec 2, 2005 | 01:04 PM
jerflash's Avatar
vmax1500....what size tire you runnin out back?
i was thinking of gettin some convopros for the rear of my car to match the fronts
im runnin 255/50/16 etstreet radials on my car right now and thats on an 8" rim so a 1/2" sould not be much of a problem
7.5" rim with a 5" back space sits the same amount in as a 10" rim with a 7.5 back space so thats why i liked about them...wont have to worry about messin up my quaterpanal when im pullin my wheels haha
just wondering did you ever try the 8,5s on your car? the trans ams are sapposed to have my clearence for tires then camaros
Old Dec 2, 2005 | 01:09 PM
onyx_rock's Avatar
I run the 15x10s out back and they do stick out a bit. I dont mind though because I only put them on when I race which isnt that often. I also dont mind the look of them sticking out. I think it looks pretty cool like that. I could see where you guys pulling wheelies might not like them though, they would probably scrape your rear fenders on launch.
Old Dec 2, 2005 | 01:30 PM
vmax1500's Avatar
In the 2 photos above I have run a 27x9 running NA and 28x10 spraying... a 9" wide tire is really the limit for a 7.5" rim... the 10" tire does not look right on the 7.5" rim... I am selling my convo pro setup to get some Bogarts... it's a little more money, but I can get a 10" wide rim that fits perfectly and they look better and are lighter!
Old Dec 2, 2005 | 02:12 PM
jerflash's Avatar
ya i would probably run a 275 on the 7.5 rim hahaha
i gotta see what i wana do and i gotta see how the 8.5s fit
Old Dec 2, 2005 | 06:17 PM
mrr23's Avatar
Hope this helps
yes it does. thanks. it looked like the 1 3/4". i used to sell wheels and tires years ago at super shops. always wanted to buy them. just never got around to it.
