Need pictures!
I would also love some pictures of different tire sizes on c6 rims too. Thanks!( btw the slight difference in tire height with the different size rims doesn't matter as long as the height ( the middle part of a tire size ) stays within 5 of each other. )
what do you guys think about the my fronts though? You think I can safely put on 265's? I've got 245's on there now and i would love to put on a wider tire without compromising the fit.
Also, the sidewall height is another problem for my front tires. i dont want them to be too tall but i have to kind of keep the wheels around the same dimension. I have 45's on i was thinking 35's or 40's with the 265.. ( Cos i've lurked here and know that it'll screw up my abs if they are drastically different sizes ... unless i can just drive with TCS off, which then who cares?) ( also dosesn't the spedo get the speed reading from the rear tires? )
18x9.5 ( 275/40/18 ) in the rear
17x8.5 ( 245/45/17 ) up front
Thanks for all your help! this board rox
and yes, i know it needs to be lowered badly
Unless there is a better place to buy than from tirerack? I don't know, i'm going to cry
