check out my pile of poop! 325x50x15s (pic inside)
#42
Originally Posted by Derek98z
Jake, I've got a different set of Bogarts right now with 28x12.5/15 et streets.
Tondss~ I would run 24lbs or less on the street.
Tondss - Are you at stock height in the rear? Just curious how easy do those 28's go in the rear?
#46
Originally Posted by slow3hoe2
imagine how sweet it would look if it was lowered in the rear about 4feet lol jk. are you running any spacers in the rear? how is the clearance on the inside of the tire? thanks
and how much air are you running in them? they look over inflated.
oh...come try out my mustang
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
funny as ****!
#48
looks good but with that big of a tire I'm sure you're gonna have a lot of drag and that may slow you down at the track unless you got the extra power.
I take it the typical banging of the wheel well, rolling the lip and cutting off the bump stop stuff was all done.
do you still have any rubbing going over bumps or taking corners?
My friend has them on hi Firebird with pro stars with 7.5 in backspacing and he said it wasn't that bad to make them fit.
