Tire size question
Im ordering the C6R Motorsport wheels with 275/35/18 for the rear and 245/40/18 in the front. is this going to fit correctly or will I have to do the bfh mod to roll the lip? Im ordering the wheels and tires from Discount and they said they have 18x9.5 and 10.5.
Thanks
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Tires I run are michelin pilot sport ps2s.
If you want to run 315/30/18 on the rear of an f-car, order ARP wheel studs and run like a 3/16" spacer on the rears, bfh the inner fender, for camaros roll the outer fender also.
the does it fit thread says
Front and Rear
7.0" ..... +35 to +40 mm .... 215, 225, 235
7.5" ..... +35 to +45 mm .... 215, 225, 235
8.0" ..... +38 to +55 mm .... 225, 235, 245
8.5" ..... +38 to +45 mm .... 235, 245, 255
9.0" ..... +38 to +56 mm .... 255, 265, 275
9.5" ..... +38 to +56 mm .... 255, 265, 275
10.0" ... +38 to +48 mm .... 265, 275
REAR Only
10.0" ... +38 to +54 mm .... 275, 285
10.5" ... +38 to +50 mm .... 285, 295
11.0" ... +45 to +56 mm .... 315
Best tires to run: 9.5" w/ a 275/35ZR18 front and a 10.5" w/ a 295/35ZR 18 rear , thats what I got.
