Telstars ???
15x8 w/ 5.5 backspacing
and some 15x4's up front
will these stick out of the wheel wells at all?
Anyone have any idea how much grinding will be needed if they will fit(any worse than a prostar)?
Anyone have any idea how much grinding will be needed if they will fit.
grinding wasnt bad on a LT car but i think the LS is alot more needed to clear them
http://store.summitracing.com/defaul....asp&x=26&y=11
I actually want to buy them from a guy and want to check them out before I spend money and get stuck with a wheels that wont work.
I ran some on the front of my car with 5/8" spacers on the 4" and they rubbed on the outer edge of my wheel well on my lowered car when it hit a dip or bump
here is the part # for the 5.5" bs
CLL-135807547
but i do got some pics of them with the 275/60/15 DR's
these where on a 5" bs
heres my caliper its a LT1 caliper
How come 15x8 prostars w/ 5 1/2 backspace works?
12's was on street tires stock stall and exhaust mods only...now I should be high 11's(cam, 3.5 k stall, better rear suspension)
Think of it this way...you're taking a 10 inch wheel like our wheels and cutting 2 inches off the INSIDE of the wheel ONLY leaving everything else the same. This makes the wheel look out of center from the wheel well. From the side it looks ok, but from other angles...there is an optical illusion of the wheel sticking out too far. (i'm talking wheels now at this point NOT tire)
If you DO use the 8 with the larger tire you would put on a 10 inch wheel, what you will do is have a larger bulge that WILL stick out further then the 10 inch typical wheel. The too large of a tire has to go somewhere...
With that said, you will limit yourself to a smaller wheel then you can fit on your car. You should NOT use a 26x11.5 ET or 275/50 on that 8 inch wheel. The tire that easily fits in your fender well but requires the necessary backspace and wheel width. I tell my customers very often PICK the tire first, THEN use the tires manufactures suggested wheel size.
Hope this helps,
Steve
Personally, the difference in appearance, weight benefits as well as fitment is worth it with our wheels. I don't have anything against economy style wheels like a prostar or draglite, they do meet their intended purpose. They don't compare whatsoever to our wheels or even welds high-end wheels.
You've probably read this recently from my other comments but wheels really make the cars appearance. It is the most visible seen alteration on a car...due to this from an appearance point of view only save your pennies and get something that makes a vast difference. I really feel you'll be most happy in the end.
I have many customers moving from Prostars/Draglites to our wheels…there is a reason for this.
By running our wheels...you will have a few benefits which is not available elsewhere that will save you in the end.
Steve
