Rotating Tires ?
Old Dec 21, 2005 | 06:01 PM
Smokn 95 Z's Avatar
Default Rotating Tires ?
If I do get the 17x11's for the rear and the 17x9.5's for the front, would I then have problems rotating my tires??
Is that even a big deal?
Old Dec 21, 2005 | 06:07 PM
rtr2001ss's Avatar
yes. If you really want to rotate, you'll have to take the tires off the rims and switch them to the other side. No front to backs. 17x11's will be using the 315's, which might not work well up front. You'll have turning problems. Besides, you don't want wider tires up front.
Old Dec 21, 2005 | 06:26 PM
Sgt. Spuds's Avatar
Shirley Temple Drinker
What is the purpouse of rotating tires? Ive heard that modern day radials should only ever be spun in on direction, so no left to right swaps..
Old Dec 21, 2005 | 08:13 PM
rtr2001ss's Avatar
I meant left/right as in taking the tire off the wheel turning it over, then put same wheel on the opposite side it came from. Tire will still be going the right direction, but on the other side of the car now. Thats the only way I see to rotate Left to Right.
Old Dec 21, 2005 | 08:22 PM
SIK02SS's Avatar
with offset wheels/tires thats the only way you can rotate.....but its pointless and your back to square one. yes of course you will have problems rotating front/back if you're running a 9.5 front and 11 rear wheel. i dont think you can even strecth a 275 onto an 11" wheel. if you want to rotate your tires, those rims (i assume zr1s) arent for you. i said screw rotating b/c i'm running 275s front and 285s rear
Old Dec 21, 2005 | 10:08 PM
rtr2001ss's Avatar
Thats how i run my Street set up with my stock SS rim's 275 up front, 285 in the rear. I don't rotate either, I was just pointing out that's how one would do it. With my Black ZR1's it's 275 up front, 315 in the rear. Also no rotating, but those are the summer tread, and the car isn't driven but 8000 miles a year. So I'm with you on this.
Old Dec 22, 2005 | 08:29 PM
Deep Blue's Avatar
Only if it is a directional tire.
Old Dec 23, 2005 | 12:45 AM
Krab's Avatar
I don't even bother rotating the tires/wheels on my car, only on a daily driver. Just make sure you have a good alignment and you're good to go.
Old Dec 23, 2005 | 01:01 AM
SSilverSSurfer's Avatar
i daily drive my car and never rotated...havent had any problems either i have 11's nad 9.5's
Old Dec 23, 2005 | 02:05 AM
1999Z28's Avatar
just think...corvettes come with different size front and rear tires...
don't worry about it
Old Dec 23, 2005 | 09:00 AM
Bio Messiah's Avatar
isnt that pretty much all you can get these days? well w/ good street tires atleast?
