315s and wheels
Old Dec 25, 2005 | 03:03 PM
GregP's Avatar
Default 315s and wheels
I see the sticky post above about 315s not fitting 9" or 9.5" rims. I have also tried looking around for wheel sizes that 315s DO fit, but haven't seen anything to date that tells me if there is a wheel out there that fits a 4th-gen Camaro and holds 315s properly.
So, if YOU are running 3.15s, what wheel type, width, and backspacing are you running? Does it rub at all?
Old Dec 25, 2005 | 03:41 PM
skatinjay27's Avatar
i i THINKS IT 10.5"-12"that a 315 fit .most people use the zr1 wheel its 11" with a 36mm offset.some get rub some dont
Old Dec 25, 2005 | 06:46 PM
SSilverSSurfer's Avatar
im using the ZR1 11" with a 50mm....rubs on the outside so i need to roll the fender
Old Dec 25, 2005 | 11:52 PM
Juiced2000SS's Avatar
I have boyd coddington rebels with a 50mm offset and 315 Nittos and fit perfect. Only modifiying the axle bumpstops so they don't hang.
Old Dec 26, 2005 | 11:53 AM
GregP's Avatar
Thanks guys.
Old Dec 27, 2005 | 09:48 PM
AbsolutHank's Avatar
I have Sumitomo 315s on my 17x11 TT2s....no issues with rubbing at all, and I haven't even installed the adjustable panhard bar. My car is also lowered with a Pro-Kit
