Sumitomo HTR Z?
Thanks for posting up the info on your run, SmokedOutZ28. I think those are 315s in the back, but can you confirm that?
Also, in case someone didn't know, the handling and treadwear ratings are not given by an independent third-party group. They are supplied by the manufacturers themselves. There is no real standard to them, so just because a tire claims AA grade traction doesn't mean that it'll perform better than another A grade tire. Similarly, treadwear doesn't mean that much either. The Sumitomos probably last almost as long, if not longer, than the GS-D3s, depending on driving style, despite the huge gap in treadwear ratings.
The main thing that is standardized is the speed rating. The tires are supposed to withstand the max speed for a given speed rating for 24 hours without failure. So even if you have an H-rated tire, you can run above the max speed of the tire for a few minutes without worrying too much about blowing out, etc. Of course, assuming everything else, like road surface, vehicle control, etc. to be perfect (which it never is).
And not to mention that W- and Y- rated tires are better than Z-rated tires.
Back on topic. Any other differences between the 275s and the 315s that might affect their grip? I know that the 315 tire isn't really that wide contact-patch-wise. Anything else?
I just priced a set of 275s & 315s, and the total (shipped) came out to $440.43. Pretty hard to beat IMO (unless of course they're only going to last 5-10k miles)
The Goodyear Eagle F1 GS-D3s probably set the standard in width/contact patch. How much smaller are the Sumitomos than the GS-D3s? How about compared to a Nitto? (I've read these run really narrow for a 315)
Or will pretty much any 315 look nasty from the rear? (I'm planning on running a 5Xmm offset 17x11 on a Camaro)
EDIT: I'm more concerned about cornering ability/handling on the street than 60' times at the track (since I rarely go). Currently running wasted Yoko AVS ES100s. How would this tire compare to the Yokos, and would it suit my needs?
*EDIT* My tires currently after 2 seasons have 5/32nds one one and 4/32nds on the other.. i had them replaced because i found a screw in one and i didn't want a plug in it! so the shop i got them from replaced them under there 1yr free replacement warranty at no cost to me!
I had Nitto D/R's before the htrz's and the nittos were better unheated and heated and in the wet. the htrz's were only better in the winter. The D/R's have zero traction on 20 degree mornings. get some nitto d/r's and some winter tires.
I REPEAT... HTRZ'S SUCK!
I like the comment that said to get them if want to feel like your car has 1000 hp. With my mods, I have a hard time getting traction all the way through 2nd gear. They can hook after a burnout but otherwise they are USELESS and basically dangerous.
Your comparing Drag Radials to Street Tires.
But I liked my HTRZ II's. At the drag strip I could only cut a 2.1 60', but then again I don't like drag racing. So I don't really care about 60'
