Pics of 315's 325's 345's
#41
Originally Posted by Twizted
you got a side shot of those wheels?
the tires are goodyear 275 in the front and sumitomo 315 in the rear. no spacer and no modification was needed.
i'm a pic *****, sorry.
#42
Originally Posted by AW/whiteZ-28
335's you can kinda see the edge of the tire on the right side under the exhaust tip.
I was thinking of trying to squeeze some 335's on a 17X11 ZR1 wheel with 50mm offset. Will it work without issues?
#43
Originally Posted by tekprodave
What rim are you running these on and what offset?
#44
Originally Posted by ls2 bait
im running 315 bfg kd's on the wheel mentioned and i have rubbing issues. my car also has the slp eiback springs.
#45
Mike
#46
aw dang. If 315's are a problem them 335's would be worse. I guess I better get a GBFH!! LOL!!
I really don't mind if they stick out a little. I just want some traction. The 275 KDWS's are useless. They even spin in third at 70-80 mph when the boost kicks in.
#48
Mike
#50
...I really don't mind if they stick out a little. I just want some traction. The 275 KDWS's are useless. They even spin in third at 70-80 mph when the boost kicks in.
#52
Originally Posted by shadow
Instead of more rubber, you might consider staying with what fits (315-335's) and look for a stickier rubber compound. A HUGE hard tire is sometimes not as good as a smaller but real sticky one
#53
True dat. I'm going to try different combinations. I ordered the MT ET drag radials in a 275/40/17 but I'm afraid it is not going to be enough. I'd like to try the hoosier drag radial on an 11" inch rim but it looks like they come in 335/35 and not 315/35. The 315 nittos would surely not stick the way I want.
#55
#56
Guest
Posts: n/a
Originally Posted by Transamman25
Those of you abusing 335's .. using Z06 Wheels ? so im guessing 335/30/18's ??
What mods were required other than a big ****** hammer ?
#57
Originally Posted by screamin chicken
I am running OEM Z06 wheels and when I corner really hard I rub in the rear with my 295/35/18 I also have the Eibach Sportlines too though.....If I can get someone to tell how to resize my picts. I will post them up......
#58
#59
That has worked I saw them on a car with that offset. I'm running 18x10.5 black zo6 motorsports with the stock vette offset, I can't remember the number though, I think its 46mm or 48mm.
#60
i dont know why people always assume that a wider tire is going to give u better traction. it will be marginal at best. if u want traction the u need to look at 2 things. tread compound and sidewall. a 17" rim does not allow for enough sideall to flex thusfor will not hook as good as the exact same tire in a 15" variety. 315's are for people who autox or for those who want a meaty look. the only reason u may think they would hook better is because they weigh more and give u that idea-but its not correct.
Your logic is somewhat flawed because you left out one factor......contact patch. And if I wanted to get max hookage I'm well aware of what a full slick can do. We are looking for max traction on a street tire with a relatively stiff sidewall. In this case the more rubber you have on the road the better.
