M/T street radials guys come in
Originally Posted by 300bhp/ton
So does this mean that a set of 255/50R16 MT ET Streets would be a better bet for track work over the 275/40R17??
Also would the 225/50R16's be OK on a 8j rim? Because according to MT's website they state a 10j rim is needed, but for the same size tyre in BFG DR's they reccomend 7-9 rim, so there's seems quite a difference - any ideas??
Originally Posted by bigdsz
I honestly don't see how the 255's could grab any better when they are 2 cm narrower, granted the side wall is 1/2" wider but I don't believe that will make up for the width difference.
I guess just try and find out what works for your car/driving style. It takes alot of trial and error, and if you practice enough with whatever you do get then you should be happy. Either way you can't go wrong with the ET Street Radial no matter the size.
Thanks for the help i see that everyone has diff opinons on the subject, i will say this that it is alot harder to get traction in a stalled auto than you m6 guys would think, i run a 3600stall 2.2 str, its pretty vilent off the line, idont have alot of power or anything but at 25psi heating them up and leaving at 1100rpm they will spin about a car length on the street, i will let you know how they hold at the track on saturday. im going to try to start off with 15psi and see if that holds.
Do some reading on tires. If the surfaces are perfectly flat then width doesn't make a difference. It's when you get an uneven surface that the width helps. A sidewall with more cushion is more important than width on a drag car. Why do you think almost all slicks are for 15" rims? There was a good article in GMHTP mag last year about tires. It gave an example of pushing a brick. Put it on it's side or flat and it takes the same amount of force to push either way.
I am picking up a set of MT street radials this spring. Having never used a set of DR's before, I usually drive around the water box on my regular street tires. Here's a couple of newb question for you all:
1)Do I need to back up into the water box and get them wet before I do my burnout at the track?
2) Im running the car in the sig with a 10 bolt: I know its a question of when, not if, its going to break, but can anyone recommend a launch technique that will prolong the inevitable with the dr's and get me around a 1.8-1.9?
Michael.
Michael.
I straddle the puddles in the waterbox with the front tires and then swing over so the rears go through the puddles. I then do a short burnout. Backing up into it would work too. Are you an M6? I ease into the clutch and have made about 20 passes so far with no problems. Several of which are 5K+ rpm launches.
Yup, im a M6. I'll give that a try.
