17x10.5 ALl the way around????
Is 17x10.5 all the way around worth while, have seen a few like this is there any problems? Would like to go with 315,s in the rear "only", what would be a good size for the front.
Do 10.5's cause any interferance problems on the front???
Well I will have to edit the thread, I dont want to do 315,s up front, just in the rear. Looking for a good size for the front. What are the most used in the front? I really don't want the skinny mismatched look between the front and the rear. So what are the thoughts on 285,s 295,s in the front. Not that much of a difference between the two. But a big change from a stock 275.
As for rims undecided at this point, either way I would like to try and keep them the same size. That is why I was think of going with a 17x10.5 on all 4 vs 17x11 rear and something different in the front.
Either 285's or 295's will not look skinny on the wheels. I was just saying that 315s are possible so a smaller is well within the realm of possiblities, sorry didnt mean to make it sound like thats what you were doing. Not many people use a wide wheel up front, so the most used tire is probably just a 275, but if i were you i'd do a 295, you'll have to make sure you get the offset to work with the front.
