C6 Wheels
Old Feb 17, 2006 | 10:47 AM
dannycam's Avatar
Default C6 Wheels
I ran a search, and I cant find what I need.
I bought a set of 2006 C6 wheels, and I am having a hard time installing the rear wheels. they are 285/35/19 and i think they are rubbing.
what spacers and studs do you guys recommend? thanks.
Old Feb 17, 2006 | 07:36 PM
WS6_MAC's Avatar
You will need a 1.25" wheel adapter if the wheels have a 79mm offset. Can be bought on e-bay for $55.
Old Feb 18, 2006 | 09:23 AM
CamaroSS621's Avatar
youll prob need longer wheel studs as well.
Old Feb 21, 2006 | 04:10 PM
ItGetsTheGirls's Avatar
Hey, i just bought those rims too. They should be in sometime in the next week, and that was the last thing i wanted to read. Where does it look like there rubbing at? What size are you fronts? Did they mount okay? Send me a pm or something, cause i feel like we might both be up the same tree.
Old Feb 21, 2006 | 04:17 PM
LS1_2NV's Avatar
That's exactly why I went with 18x10.5 with 285/35 in the rear. They are close enough to rubbing!
Old Feb 21, 2006 | 06:04 PM
I just bolted mine on and I have rear prokit springs. Havent had a chance to drive it yet
Old Feb 21, 2006 | 07:59 PM
cabesas's Avatar
im having a hard time with the rears
Old Mar 6, 2007 | 08:33 AM
JasonWW's Avatar
More info here:
https://ls1tech.com/forums/wheels-tires/574767-fitting-79mm-19x10-c6-rims-my-formula-experience.html
Old Mar 6, 2007 | 11:35 AM
cocimitch's Avatar
The rear gole in the center of the wheel may have to be "relieved" a little by using a file or mototool. If I remember right the center part of the hub is a little bigger on the axle, but not much.
If it is too small - DO NOT FORCE the wheel on - ream out the hole a little
Chime in guys if I'm wrong!
Old Mar 15, 2007 | 02:54 PM
JasonWW's Avatar
What kind of caliper clearance in the front are you guys getting? Anyone have a pic?
Old Mar 16, 2007 | 02:11 PM
96lt1m6's Avatar
i had to instal rear spacers and do some hammering,i also ended up cutting the jounce pads off
