View Poll Results: Would you like Centerline to make Convo Pros that fit '03 to '02 F-Bodies?
Yes
315
92.65%
No
9
2.65%
Neutral
16
4.71%
Voters: 340. You may not vote on this poll
Would the '93 - '02 F-Body guys be interested in Centerline Convo Pros that fit?
#121
Seriously guys, if a few phone calls would help lets get something going. I know handful of guys in my local area that would love to have something different from draglites and prostars. It is sad there are several cars even the same color with the same wheels in the same very very small town area.
Me myself, Id like to see some telstars setup properly if it were ever a possibility, of course the cost is a part of what makes them so attractive so if they feel they have to raise the cost to offset the production of any of these wheels then it would be pointless because I would just buy Bogarts in that case most likely and not have to grind the **** out of my brakes. If I could get a set of Telstars with the correct BS for the current pricing that JEGS has for them then Id be all over it and sit outside with a grinder all day if I have to.
Is anything gonna come of this or what, if I can help I will.
#122
LS1Tech Co-Founder
badpewter, do you still have both sets of rears?
I'm talking to Centerline about getting one wheel and then having someone test fit it for them/us. You are a good candidate since we have the other pics.
#123
LS1TECH Sponsor
both sets? i have the ones i listed above . those are the only center line rears i have
any way i can help just let me know
we defiently need more choices of wheels that fit correctly w/o modifications
#125
Whoa whoa.. So what exactly from centerline will fit on my 99 T/A without grinding calipers? 15x10s? telstars, convo pros? I thought that they would fit w/out grinding? I'm not worried about it sticking out further.. GOSH!! I just can't win.
#126
Any info?
#127
#130
I have a set of 15x7.5 convopro's on mine with 5" backspace,if you add to the inside
of the wheel it will work.It would end up being 15x9 with a 6.5 backspace,same distance to the edge of the fender as the welds,one inch narrower so more clearance on the inside.
#132
I'm working on getting one rear rim, and then having a few folks test fit it.
Dan
#138
Originally Posted by gillbot
Not everyone wants the 10", I'd be happy with the 8.5's as well. Given the choice between the two, if the price was similar I'd do the 10 just because.
#139
Originally Posted by LS69TA
Yea, I tried on my buddies Convo Pros, they just stuck out a little more than I wanted. I'd have bought Telstars, but I read that they required more grinding than the Prostars. I'm in favor of a new style too
